when you reset the switch it turns it back to the settings it had when it came out of the box. Try the default factory username, password and IP address
Connect the console cable, open a connection to the serial port via a utility such as PuTTY, and do the following: 1) Enter the user name "recover" and password "recover" to place your unit in password recovery mode. The unit will remain in password recovery mode for 30 seconds max. 2) Perform a hard reset by removing power, waiting 10 seconds, and then re-applying power. 3) Once the switch has rebooted, enter a new password for the "admin" user account. 4) Enter enable to leave password recovery enabled, or enter disable to turn it off. You are now logged in as the default "admin" user. Note: If password recovery has been disabled, the only way to recover access is to return the switch to 3com.
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To
change the Default User "ADMIN" password it is necessary to use the
Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
prompts to confirm the New Password In order to complete the
configuration it is necessary to save the configuration via the WEB
INTERFACE
-Web Interface
-Device > Configuration > Save Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled Cause:
When applying the new password, by default
the service-type is set to "telnet". When applied, the default
"terminal" setting is removed thus disabling console access.
First,"There is usually a small button on routers that can be accessed with the tip of a pen or a paperclip. When you find that tiny button, hold your pen or paperclip down on it for approximately 10 seconds until the router resets itself to factory defaults." After that, you can contact the manufacturer to get some helps if you still have problem.
BTW, I work for Ingellen Communication Equipment and we are a large fiber optic equipments manufacturer in Shenzhen.Kindly let me know your specific requirements so that i can help
To reset to factory Default settings you need to do the below steps
1. Look for the reset button. The reset button is a tiny black button on the back of the switch. 2. Power Off the switch. 3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that. 4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button 6. Wait for 5 minutes. The switch will boot up with factory default settings.
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
