Run a diagnostic on the door lock system; To place the unit in "service mode", close the door completely then press and hold both the "Delicates" and "Heavy Soils" keys for three seconds. Motor speed will be displayed. Press "rinse" to access the main board output function. Then press "max extract"... this is the test for the door lock. Did it lock? To exit, press "max extract" again and then both "Delicates" and "Heavy Soils" for three seconds.
VOLTAGE TESTS AHEAD!!! IF YOU AREN'T SURE YOU CAN DO IT, THEN DON'T! CALL A PROFESSIONAL!
If the door did not lock, you'll need a voltmeter and an hour or so. Open the door, remove the screws holding the door hinges, then remove the 2 screws (and shims) opposite the door hinges and close the door (do not take it off). Then grasp the front panel at the top near where it meets the top panel and pull toward you quickly. Lean it forward and remove it from the 2 clips at the bottom. Just below the top panel, now exposed, are the top panel retainers... use a 5/16" to remove the one screw on both sides and remove the retainer clips. Now lift the top panel up just like the hood of a car. You can now see the door latch assy. Remove the 2 wires on the solenoid and insert your meter probes into each one of them (color doesn't matter). Set your meter to read AC Voltage, then re-enter "Service Mode" and follow the steps to door lock test. When you hit the "Max Extract" key, 120 volts should be sent to the meter. If you get 120 volts, your latch assy. has failed and should be replaced. If you don't get 120 volts, your control board output has failed and needs to be replaced. Hope this helps.
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Check whether the door switch is not jammed in the closed position. It closes an electrical circuit when the door is closed, so if it is stuck in the "closed" position, it is giving a signal to the main control board that the door is closed when in fact it is open.
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
The proper way would be to look at a wiring diagram an test the electrical circuit's with a DVOM - digital volt ohm meter . Do you know how to test automotive electrical circuit's ? Electric Testing Techniques You Need to Know The Trainer 32 How To Read An Automotive Block Wiring Diagram
Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter the vehicle info. year , make model and engine size . Under system click on body & accessories ,then under subsystem click on power sliding door . Click the search button then the blue link. Looking at the diagram you will see a control module is used .
Also reading factory service info. on how it works would be a good idea.
Rear Side Door Actuator Control Module
The rear side door actuator control module is capable of on-board diagnostic functions described in On-Board Diagnostic Features . The rear side door actuator control module monitors the door position at all times including during manual operation. After activating the on-board diagnostic modes, loosing battery voltage, or ground to the rear side door actuator control module the Power Sliding Door (PSD) Re-Initialization procedure must be performed in order for the rear side door actuator control module to correctly determine the door position.
Power Sliding Door System Description
The power sliding door system(s) can operate correctly only if the power sliding door is in proper mechanical condition. Any mechanical problems will affect the power sliding door operation and must be repaired before attempting to diagnose the power sliding door system. Manually open and close the power sliding door to determine if the door moves smoothly and without excessive resistance or binding. The power sliding door must also latch and unlatch without the use of excessive force. At any time during power sliding door open or close operation, excessive resistance to the door movement will cause the power sliding door to stop and reverse the direction of travel.
The power sliding door will operate only when the power sliding door on/off switch in the overhead console is in the on position. At anytime during power sliding door operation the on/off switch may be turned to the off position and the system will quit any function in process. The power sliding door will not open unless the transmission shift lever is in the park position and the door is unlocked. When the sliding door security lock is in the locked position the power sliding door will not open from the inside. The power sliding door close function will operate when the vehicle is in gear. The power sliding door module uses the VSS signal to determine if the vehicle is moving during a power sliding door close function. The momentum of the vehicle moving forward adds resistance to the door closing operation. When the rear side door actuator control module determines the vehicle is moving forward while closing the door, current flow through the actuator motor is increased instead of being reversed. The VSS signal circuit is supplied battery positive voltage through a resistor then monitored within the rear side door actuator control module. The VSS signal circuit is then pulsed to ground, or pulled low by the powertrain control module in relation to vehicle speed. The sliding door alarm will sound repeated short tones whenever the power sliding door system is turned on and the door is open while the transmission is out of park.
When the power sliding door system is on and manual operation of the power sliding door is detected the rear side door actuator control module activates the power assist feature. When the power assist is activated the power sliding door will continue to open or close without any further manual effort.
The power sliding doors may be operated using the Remote Keyless Entry System. The keyless entry transmitter will have one OPEN/CLOSE button with a van symbol on it for each power sliding door. The power sliding door ON/OFF switches in the overhead console must be in the ON position in order to operate the power sliding doors using the keyless entry transmitter. When a right hand power sliding door OPEN/CLOSE function is activated using a keyless entry transmitter the exterior lights will flash once indicating the RKE module has received the OPEN/CLOSE command. When activating a left hand power sliding door OPEN/CLOSE function with the keyless entry transmitter the exterior lights will not flash.
The left and right power sliding door systems operate as independent systems. The on-board diagnostic modes are entered and operate the same in both systems.
The power sliding door systems are capable of the following on-board diagnostic functions:
• Diagnostic Mode 1: An audible signal indicates the diagnostic trouble codes stored by the rear side door actuator control module.
• Diagnostic Mode 2: An audible signal indicates when inputs to the rear side door actuator control module are active.
• Diagnostic Mode 3: Performs an output test of the sliding door unlatch actuator.
Entering On-Board Diagnostics
The on-board diagnostic modes can only be entered in a sequential order from modes 1-3.
• Enter the right power sliding door system on-board diagnostics using the right B-pillar open/close switch and the right on/off switch in the overhead console.
• Enter the left power sliding door system on-board diagnostics using the left B-pillar open/close switch and the left on/off switch in the overhead console.
1. Both power sliding doors must be closed and in the latched position.
2. Place the ignition switch in the OFF position.
3. Place the on/off switch in the overhead console to the OFF position.
4. Press and hold the B-pillar power sliding door open/close switch.
5. While holding the open/close switch, operate the on/off switch through 10 ON and OFF cycles within 10 seconds stopping in the on position.
6. The sliding door alarm will sound 1 long tone indicating diagnostic mode 1 is active.
Diagnostic Mode 1
Upon activating diagnostic mode 1, DTCs will begin to be signaled by the sliding door alarm. The DTCs are 2 digit codes and the codes are represented by the number of buzzes for each digit of the code number. For example a DTC 12 is represented with the following sequence: buzz, pause, buzz, buzz, long pause. Each DTC will be signaled 3 times before proceeding to the next DTC. Refer to Diagnostic Trouble Code (DTC) List . The DTCs will continue to be repeated in this manner until the on-board diagnostics are exited or mode 2 is entered. When exiting the on-board diagnostics all stored DTCs will be erased from the rear side door actuator control module memory.
The error code D5 OR DS is the same.Its mostly DS which looks like D5.
The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
This error code indicates that the door is not locking. Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it. Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
Unplug the washer or disconnect the power for one minute.
Plug in the washer or reconnect the power.
Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
