SOURCE: When I try to print a black and white document it
Kindly reseat the cartridges 2 time and then close the access door .Clcik on Menu on the printer and scroll down and choose Clean printhead and select "deep cleaning" Print a demo sheet after the cleaning process has been completed. If ur issue persists,Call Kodak @ 1800 421 6699 and they will replace printhead of the printer free of cost. Printhead is the part which takes the ink out from the cartridges.Probably the printhead of the printer has gone bad.
Testimonial: "Thanks, appreciate the quick feedback!"
SOURCE: I need a manual for a Toshiba 1360 black & white copier
here is a link to the owners manual link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: Toshiba eStudio 2830c-getting a light line across
Hello sir; Is the stripes allway in same place and you use document feeder to copy, then you have to clean up a piece stripe glass on the plateform, otherwise ,you have to change drum cleaning blade or drum cartridge.
SOURCE: COPIERS - E-STUDIO 650 Copier: We have a Toshiba estudio 550 copier and are copyi...
Copier is copying pages with dark areas down at the bottom.
SOURCE: Canon Pixma 3600 I want black
The Grayscale print option optimizes the look of color slides for printing on a black and white printer by adding shading. The Pure Black and White option prints your slides in monochrome.
example:
5.In the Color/Grayscale section, choose the Grayscale option to print in black, white, and shades of gray.
6.Choose the Pure Black and White option to print in black and white only.
7.Click on the OK button.
