Re: My HP 110 envy printer is printing double images.
Hello there,
It sounds very much like your printing software is not set up correctly.
Try re-installing the Printer software or better still, take a look at the print menus which you should be able to access from 'Control Panel' if you have a Windows machine.
I doubt VERY much that there is something wrong with your Printer.
It is your Computer telling it to print twice.
If you are using thermal paper, Turn the roll upside down (I had the same problem).
If you don't use thermal paper please ring HP on 1 300 888 423 they will tell you whats wrong for free, If the Facsimale is faulty and is under warreanty they will fix it.
Yes , if the fax machine says low ink or toner , then it needs it alos check the drum corona wire, It may need cleaning, and you can clean it using a #2 lead pencil eraser, Gently in the wire, then replace wire and try receiving a fax.
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
If it is only printing the top half then it is quite possible you are running out of ink. Try printing on only black and see if this works. When is the last time you replaced the colour cartridge?
Regarding your recent inquiry about the HP 61 black.....OR....HP 61 color ink cartridge error message and inability to print to your HP ENVY 5530 printer, this type of problem could be an electrical connection issue between the printer and the cartridge (i.e. dirty electrical contacts on either the cartridge or printer carriage flex cable surface), or more likely, an internal micro-electronic failure inside one of the HP 61 ink cartridges (please note it is very rare for both ink cartridges to fail at the same time - hence one of them is likely causing the current issue).
To determine which cartridge is causing the error condition and to check the electrical health of both ink cartridges, please run the 'Tap 41' diagnostic test below (PROCEDURE B.).....
NOTE: If the LCD screen is 'frozen', then one of the ink cartridges is likely suffering from marginal internal electrical performance and may need to be replaced - SEE DIAGNOSTIC STEPS BELOW. Please visit: http://inkjet411.com/?page_id=396
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
An internal electrical failure of a cartridge can be confirmed by performing the following steps which will help rule out other variables which could also be causing the issue.
DIAGNOSTIC STEPS:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test (refer to 2nd video at the following link so you understand how to analyze the test print - though you will use steps 1 thru 6 below to activate the test report): http://inkjet411.com/?page_id=1476
1.Using two fingers, gently tap the 'Return' and 'Home' keys on touchscreen until the 'Support' Menu is displayed (for example, press the button 3-4 times each in alternating succession).
2.At 'Support' menu, select the upper right button until the 'Reports Menu' is visible. Select OK.
3.Press upper right button until 'print mech button tap' menu is displayed.
4.Press OK, the 'code = 0' menu should be displayed.
5.Use arrows keys to change value to 'code = 41' (i.e. press and hold right arrow key). When 'code = 41', select 'OK'. NOTE 1:The Tap 10 self-test print may also be initiated via 'code = 10'
6.The diagnostic 'tap 41' test report will print. (see video here: http://inkjet411.com/?page_id=1476 )
-- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health. A good HP 61/61XL color cartridge should display 612 good nozzles, while a good HP 61/61XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced.
---If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink. Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one (or both) of the ink cartridges is damaged.
C. Print the Self Test Page (HP TOUCHSCREEN MODELS; when cartridges are functioning normally with no cartridge errors):
1. Load plain white paper in the input tray.
2. At printer's LCD screen, navigate to TOOLS menu.
3. Choose 'Printer Status Report', - the self-test report should print.
*Many cartridges eventually do encounter problems or failures. The "Incompatible Cartridge(s)" / "Print Cartridge(s) Problem - Refer to printer documentation."error message is typically indicative of failed micro-electronics internal to the ink cartridge(s). Also, it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active state of both cartridges.
For reference, the following page provides a complete review of the majority of cartridge fatal error messages you may observe on your printer at one point or another: http://inkjet411.com/?page_id=415
If your printer works routinely after inserting a brand new HP 61/61XL black.....OR....color ink cartridge in it, this will confirm root cause per the suspect ink cartridge.
Unfortunately the micro-electronics in many of the newer HP 61 integrated ink cartridge lines are quite fragile (due to low-cost materials used in the manufacturing processes), so results of repeated cartridge usage/longevity will vary from one extreme to the other. As a suggestion, if you print more than 15 pages per week, then you may want to consider moving over to an 'individual ink tank' printer system....these are very "refill friendly" and you will not encounter cartridge failures. For information on REFILL FRIENDLY printer models please visit our support site: http://inkjet411.com/?page_id=3585
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors.
If you ever need to purchase a new HP 61 ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (purchases available to USA residents only). These are refilled original ink cartridges which have been electrically bench tested to guarantee satisfactory performance.
For any additional questions you may have please contact us directly: [email protected]
The Inkjet411 site is a self-service printer support sitelet which provides over 80 technical videos and do-it-yourself printer remedies and corrections: http://inkjet411.com/
To save ~70% on HP 61 ink costs, go to any of these retail outlets and have your ink cartridge refilled:
Alternatively, if you need to purchase HP 61 ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA (half the cost of an HP original cartridge), have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20.
For any additional questions please contact us directly: [email protected]
if you are using refilled cartridge, it wont show the level cuz HP wants your money for a new HP replacement.... if you look at lcd on printer and touch the icon with wrench you will see the ink level display or option somewhere, i forget exactlly but very easy to find. good luck
