I need to change the main control panel.
SOURCE: Loud banging/thumping during spin cycle on my kenmore front load
this sounds like this could be the bearings,to check for this,open door and with yourhand lift the inner chrome drum and let it fall then lift again and if you feel a knocking sound and a lot of play in it then its the bearings,i know there should be movement in the drum but this will feel more of a knocking.
SOURCE: Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
SOURCE: Kenmore washer model 110.24872300, need to romove control panel
if u got rooom just tip the unit back and get acesss underneath it will be a lil bit tighter space to work but will save you the time and hassle of removin the concole......... u will need a part # 285753A- whirlpool motor couplling.... most those consoles remove though by screws on backside corners or front corners, remove those tilit concole back remove brass brackets, wiring lid switch, pull cabinet off hope this helps
SOURCE: kenmore 80 series washer is it energy efficient
yes
and
yes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: how do you remove the
There are several ways to take apart the control panel based on when it was made. This youtube video will how you how to do that on all models http://www.youtube.com/watch?v=Puq8jWMY9Iw
Good luck,i hope this helps
Gene
