Electronics - Others Logo
w
william smith Posted on Nov 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My model number: PMID921X (4GB) my problem is that the charger, made by Powerline has a voltage selector with options of 3V to 12v, and an usb option. And on the side is a switch for + - and - +.
My model number: PMID921X (4GB) my problem is that the charger, made by Powerline has a voltage selector with options of 3V to 12v, and an usb option. And on the side is a switch for + - and - +. I have no manual. What selections should I make? I live in Alabama, USA, btw. Thank you for your help
anthony alagon
Level 2:
Habit-Forming:
  • Expert 170 Answers
  • Posted on Nov 22, 2017
anthony alagon
Expert
Level 2:
Habit-Forming:
Answers
170
Questions
0
Helped
37911
Points
461
5 Related Answers
A
Anonymous
  • Posted on May 24, 2008
SOURCE: Menu Selection does not work
I had the same problem with the same player for some DVDs. Fortunately, for me, there is a solution that has worked 100% of the time.
I am assuming you are probably setting the DVD player to upconvert to 1080 i or p. What you need to do is go to DVD setup and change the resolution back to standard def (480i) just for the menus. The menus will now work properly. Once the movie starts you can switch it back to 1080i/p with no problem.
s60six
  • 328 Answers
  • Posted on Dec 15, 2008
SOURCE: Hello, I'm from USA visiting
here's the link for the owners manual http://www.japaneseautospares.co.uk/ownershandbooks/mitsubishi.htm#rvr
sorry i dont know much about this vehicke or where the jack would be:(
hope this helps....Good luck!
Anonymous
  • 81 Answers
  • Posted on Mar 26, 2009
SOURCE: 4wd selector switch quit
Most of the time, the selector switch is bad.
Anonymous
  • 81 Answers
  • Posted on May 20, 2009
SOURCE: remove write protection from memorex USB travel drive (4GB)
Go to Driver Detective and check your drivers.
Anonymous
  • 3 Answers
  • Posted on Oct 26, 2009
SOURCE: ford s max with an optional extra of an electric
if you look in the boot where there may be a spare wheel there can sometimes be a leaver thich will overide the automatic system
2answers
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 • Cell Phones
2answers
Battery does not want to charge
Could be variable reasons -> If you're using generic brand chargers or charger adapter (these have various voltage settings on them and numerous tips for insertion into charging location on unit). This is often an issue with regular cell phones as well. If you don't use the same brand charger (or at the least, one of the reputable 3rd party manufacturers, ex: Belkin)...Most importantly, make sure the charger output matches input of the phone. If you're unsure, check you owners manual for specifications. Do the same for your charger specification. If it's quicker to use the internet. Search the net for your phone model. This also includes the info you need for the charger...Depending on the age of the battery and/or the tablet/e-reader. Again, there could be many variables
How do i fix a Hp Hewlett Packard photosmart r937 digital camera?
Not sure on the camera model but cameras usually don't take 12v so I would comparability of charge voltage would be the problem. Cameras take 3v to 6v usually. Check the specs of your camera that will tell you what it needs. Hope this helps.
3answers
What kind of fuse do I need for the symbol 4 slot battery charger
The UBC 2000 Fuse part number: 217005 (5A 250v Quick Blow), orderable from Little Fuse (Phone: 847-824-1188).
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
2answers
Meos dvd92b not charging
Hello:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Dec 29, 2012 • Cell Phones
7helpful
3answers
Nokia 3110c Charger not supported
First Option:
Second Option:
2answers
Need to know voltage for charger. Have lots of
I have similar problem but for GE 86707? What DC output is required?
2answers
Vivicam 4345 Not Charging
As universal charger with heads for a variety of voltages would seem to be the answer- check the voltages available
Top Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
