Wich control light doesn't work. When I push in the light don't turn off. door alarm always beep..beep... so how can I fix it?
SOURCE: side by side GE refrigerator psf26pgta
The fan should be a standard 12v DC computer style fan , test that you are getting voltage to the fan connector . You should also be able to get the fan to run by connecting it to a suitable supply . Once you have eliminated the possibility of fan failure then it gets more involved.
SOURCE: The light and digital controls on the refrigerator side dont work
I replaced a circuit board that is in the white box at the lower left rear of the fridge. You will need to remove the cardboard cover, then there is two screws to loosen the box. The circuit board is inside. There is a white tab that sticks up push it sideways and it will pop right out. Put the plugs in the new board and pop it back in and put everything back together. Be sure the wires are routed so they do not contact the compressor.
If you want to test it first get a voltmeter one probe to CN1, the white wire, and the other to CN2, yellow wire with red stripe, there should be 120 volts. If not, or when the door is open it drops replace the board.
I did not have a voltmeter but it seems everybody that had a problem the fridge was 4 to 5 years old. So I bit the bullet, around $90.00, and replaced it and it works!
SOURCE: Side by side GE refrigerator freezing food in refrigerator.
The unit is having a damper control issue. In the back of the refrigerator there is an assembly that is in the center at the top. It connects to the freezer side. The damper is broken, cracked or has an obstruction. Check this and see if it is the problem.
Btw, Iām available to help over the phone in case u need at https://www.6ya.com/expert/robert_e97a69269ae71345
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
