Hello friend, thank you for your post!
I see that your door ajar alarm is going off when the door is closed to your Frigidaire freezer. It sounds like a possible issue with the control panel or switch. Let's perform a reset to your appliance to see if that will correct the issue. You can do that by disconnecting power from the appliance for roughly ten minutes. I hope this helps. -Matt
SOURCE: door was not sealed tightly
The door seal has a magnetic property to it. Until the freezer gets to a certain degree the magnetic porperties of the door seal dont react properly. Make sure the door seal is properly adjusted. If the door was left open it could have semi warped the door. This gets corrected when temp drops to correct temp. Reset freezer by unplugging and waiting for a few minutes. If problem persist contact appliance technician.
If you have any more questions you can comment me back.
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
