Change the halogen light bulbs
Just look this youtube video, and it can't be more clear.
Don't forget to unplug the hood, or switch it of. Although the halogen lamps are only 12 volt. In the hood are dangerous voltages. How to replace cooker hood halogen bulb or lamp
SOURCE: How do you change a halogen bulb in my dacor range hood
Believe it or not - they just unscrew like regular light bulbs. There is supposed to be a suction cup that came with the hood to replace the bulb - we lost ours. I was able to remove it by using a little bit of pressure on the face of the bulb and twisting it back and forth. The other bulb was stuck, so I made a "handle" using duct tape on the face of the bulb.
SOURCE: ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
SOURCE: Can not get halogen bulb out of my kennmore elite range hood
You will have to do the following steps.
1. remove filters
2. Unscrew 2 screws retaining metal plate under the filters.
3. Now you must remove the whole light panel. 5 screws in all, three under the front lip and two at both back ends of the same panel.
4.You now unhook the light wires (plastic connector with two wires)
Now you have the whole pnale in your hands. Unclip the socket of "problem side" and unscrew the socket from the bulb. Re-do steps 4.3.2.1
SOURCE: Dacor IVS1 Vent Hood - How to change a light bulb?
Buylighting.com, JDR120V-75W-E27CG...also comes in 50 watt. They aren't inexpensive, but if installed properly, will last a while. We have a little suction cup to take them out and put them in. It came with the range hood. If you get fingerprints on a halogen bulb, it can blow out quicker.
SOURCE: How do you change the
Turn off power before attempting work on the hood. Bulbs are removed by turning counter clockwise. The manufacturer recommends using a latex glove or suction cup as the bulbs to tend to become stuck with prolonged use.
If you have the E-30AS hood the bulb will twist only a quarter turn before it can be pulled from the socket as it uses a clip-in type socket.
The E30S uses a screw-in type connector.
Download your user and installation manual here.
