Adjusted dial two or three times a week ; back isn't frozen solid; just frosty. Having hard time controlling temp. We can increase temp; back will thaw and be normal for couple days and then too warm --- vicious cycle
SOURCE: Sanyo SR-4912M 4.9 cu ft refrig temp problems
Greetings macx,
The average refrigerator temperature is between 35 & 38 degrees. The maximum temperature a refrigerator can be before bacteria begins to grow is 39 degrees. It would be my recommendation to exchange this unit if you can at your local retailer. If this was purchased at Best Buy, you have a 30 day return/exchange policy on this item with no restocking fee.
Thank you,
Agent Dort
Go Ahead. Use Us.
SOURCE: Where to buy Sanyo SR-366 parts? I need a freezer door.
I will probably have one, I'll look to see if it can easily be removed.
SOURCE: freezing at any tempeture
I ordered a new thermostat (about $40 with shipping) & installed it. It's pretty easy to replace. The fridge has been working fine since.
SOURCE: Sanyo 4.9cu.ft. compact refrigerator heats rather than cools
I'd already picked up a replacement (B&D 2.7cf) before I found the website and asked the question,,,, hoped for a quick fix answer and I'd be able to return the B&D.... oh well. With 'designed' obsolescence and 'disposable' appliances, Robert L's answer confirmed my 'fears'.
Now I'm trying to find someone locally (Conroe, TX) who would like to 'recycle' the Sanyo (everything but the compressor/motor is in great shape - door, glass shelves, etc. maybe even the coolant which I don't want to 'dump' in a landfill.
SOURCE: I have a Sanyo SR-4910M refrigerator. It
fAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
