I want to copy a file onto a DVD from a flash drive
SOURCE: how do i use my new sandisk cruzer?
insert the flash drive into your computer and wait for it to be recognised by windows. Once it has been recognised and installed it will tell you that it is installed and ready to use.
The just go to wherever it is on your computer that you have your photos stored, select your photos right click and click on copy, then go to 'my comptuer' and double click on your flash drive to open it and paste your picture there.
Or select your photos, right click, select sent to:- and send to your flash drive, it may be recognised as removable storage.
SOURCE: I have a cruzer micro 16Gb flash drive with 14.9Gb
Did you reformat as NTFS instead of the default FAT32? FAT32 can only transfer files up to 4.0Gb in size. If you reformat as NTFS, you can move larger files.
SOURCE: how do I get info to correctly use my san disk flash drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
SOURCE: unable to format my SanDisk Cruzer Micro 8GB USB
