The Best Way to fix "iPhone forget passcode (Recommended)
They will suffer tremendous data loss once they wipe out their phone data. However, there is another recommended solution that will not let go of your phone contents easily. FoneDog Toolkit- iOS System Recovery (Repair) allows you to fix 'iPhone is disabled, Connect to iTunes' error in just a few minutes and without erasing phone contents.
Step1. Download FoneDog Toolkit- iOS System Recovery
Step2. Connect the iPhone to the PC
Step3. Download the iOS firmware package
Step4. Wait until the process is completed and unlock your iPhone
Totally guide: Learn to Fix iPhone is Disabled Connect to iTunes Error?
Hope this guide helps you. It's about restoring iOS devices without iTunes. How to Restore iPad Without iTunes
Don't you have paper work if you don't take the phone to the store and ask the cashier for some helunch with your phone if they can't do anything buy a new phone.
BUT HOW TO CONNECT ITONES.THE DISPLAY IS LOCK.
Hello there.
Because it says disabled, you cant restore it !!!!!!
Go here and follow the instructions.
http://www.unlockboot.com/2013/05/iphone-is-disabled-error-fix-without.html
OR
Go here and follow instructions EXACTLY
http://iphoneblogr.com/2012/07/how-to-unlock-your-disabled-iphone-and-recover-your-passcode-disabled-iphone-passcode-recovery-iphone-ipod-touch-ipad/
SOURCE: Can't get iphone out of Emergency Mode! Help Plz
Funny same name to ok ive had this problem lets see if i can help. has your iphone worked before if yes have you jailbroke it with anytype of program?
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
SOURCE: My iPhone is disabled for 4,566,757 mintues, HELP!
The only way is to reflash a new firmware and wipe the code as well as the phone clean.
To do this start itunes on your computer. Then connect your phone to the computer. Once itunes detected your phone hold the POWER and the HOME buttons down at the same time for about 10 seconds. Once the phone flashes off, let go of the POWER button and keep holding the HOME button until you see a message on the itunes telling you that your phone is detected and needs to be RESTORED. Follow directions and it will do its job. I appreciate your positive vote. Thanks
SOURCE: Forgot Lock Code - Samsung m500 Cell Phone
try to use last 4 digit of your phone number . go into the menu then setting then security then enter four digets and you can find these 4 degits into in setting then phone info enjoyyyyyyyyyyyyyy
SOURCE: Got unlocked iphone, tried to restore factory
Here u can follow the steps
Step 1: Make sure you have downloaded the latest version of iTunes if you haven’t already. Download iTunes 8.2 from the link given below.
Step 2: Now connect your iPhone with your PC. You must connect it to a single usb port on the backside of your computer. Do not use any usb hub or the ports in the front as this could cause an error during update process.
Step 3: Start iTunes 8.2. Sync your iPhone with your PC so that iTunes backs-up all your important data including settings, apps, music, contacts and photos.
Step 4: You will now have to download a custom cooked firmware for your iPhone version (2G or 3G). I can’t post the download links for these files for the reasons you all know very well. Just Google “iPhone 2G Custom 3.0” (If you are using iPhone 2G) or “iPhone 3G Custom 3.0” (If you are using iPhone 3G) and use one of the torrent links to download the custom created .ipsw file.
Step 5: Once you have downloaded the required .ipsw file, Copy/Paste it into this location:
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows 7)
“C:\Users\[username]\AppData\Roaming\Apple Computer\iTunes\iPhone Software Updates\” (Windows Vista)
“C:\Documents and Settings\[username]\Application Data\Apple Computer\iTunes\iPhone Software Update\” (Windows XP)
Step 6: Restart iTunes. You will now be prompted to install this firmware you just download. Just close this prompt dialog by clicking on “x” from the top right-most corner of the window.
Step 7: Now you will have to restore your iPhone to this custom firmware 3.0 that you just downloaded. Click on your phone from the sidebar in iTunes to get to this screen as shown in the screenshot below:
Now press and hold left “Shift” button on the keyboard and then click on “Restore” (Not “Update) button in the iTunes and then release the “Shift” button.
This will make iTunes prompt you to select the location for your downloaded custom firmware 3.0. Select the downloaded .ipsw file and click on “Open”.
Step 8: Now sit back and enjoy as iTunes does the rest for you. This will involve a series of automated steps some of which are highlighted below:
Don’t do anything silly at this point. Just wait while iTunes installs the new firmware 3.0 on your iPhone. Your iPhone screen at this point will be showing a progress bar indicating installation progress. After the installation is done, iPhone will restart automatically and you should now have a fully unlocked and jailbroken iPhone 2G. iPhone 3G on the hand will only be jailbroken, not unlocked. iPhone 3G users will have to wait for Dev-Team to release ultrasn0w on Cydia in order to unlock their phones.
Step 9: Once you are done with the unlocking and jailbreak process. You can now restore all your settings, apps, music, contacts and photos to the newly installed firmware version 3.0 by restoring the backup that you made in Step 3 from iTunes.
Feel free to ask me any question here should you run into any problem during the update process.
Disclaimer: This guide is for testing & educational purposes only. I’m not responsible for any loss of important data or malfunctioning of your iPhone.
Download Links:
Download iTunes 8.2
Download iPhone OS 3.0 Custom Firmware (iPhone 2G) [Screenshot]
Download iPhone OS 3.0 Custom Firmware (iPhone 3G) [Screenshot]
Thanks
Thiru
