It was just working earlier today. Now nothing works. None of the buttons on the TV will turn it off, change channels, or show the menu.
SOURCE: Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
SOURCE: proscan tv model 19la25q
I need a replacement power supply...Any idea where to get one for this model?
[email protected]
SOURCE: I have tried to program my FiOS Verizon remote
Thank you. I did solve my problem with some diligence. The instructions from Verizon were correct. I realized that there are two buttons on the Verizon universal remote that look alike - the "play" arrow and the "fast forward" double arrow. Once I used both of these buttons in the proper sequence, reprogramming the TV remote with the new code worked.
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
SOURCE: green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
