Question about Jenn-Air JED8430 Electric Cooktop
How to take off top of cook top to access the control for one of the burners?
I need to remove the top off the cooktop to access controls
    Dedicated:
    Visited the website for 20 consecutive days.
  • 436 Answers
Ok Hello there.
Number 1)
There are several types of this 8430 but all will be similar . For the complete set of machines if you REALLY need the EXACT one.go here http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JED8430&siteCd=JA_EN_US&userType=Servicer#installation_instructions
Number 2)
PLEASE don't 'fiddle about' with the cooker if you don't know about electrics. There are VERY high powerand DANGEROUS electric cables in there ! This is Nothing like a low power Stereo or TV BE CAREFUL !!!!
Number 3)
I am not familiar with this top but it seems from the diagrams that it just drops in to a base unit that contains the fan unit.somehow. I don't see any screws in the surface of the top so TURN OFF THE POWER COMPLETELY take out by lifting the edges ; the whole thing and work on it from underneath to access the electrics..
These diagrams below will show you all you need to do the job. READ THEM THOROUGHLY BEFORE you start.
PLEASE BE CAREFUL with Electrical wiring. !!! I cant stress enough
Owners Guide
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208111P415-60.pdf
Parts list and circuit diagram (if your switch is playing up.this will help)
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20JED8430ADB.pdf
Installation
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P419-60.pdf
Posted on Sep 20, 2014
2 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 59 Answers
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
How to remove the top panel of the cooktop?
To remove the top so that you can replace the electrodes, you just need to pull all the burner grates off and knobs. Then remove all the burner caps and rings off so that all you're left with is the cooktop and the burner bases. There are screws going into each burner base. Remove all the screws and the burner bases will pull up and off and then you can pull the top of the cooktop up and off.
Feb 13, 2013 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
How to change wb30t10062
remove the cook top from the counter and the remove the glass top, several screws around the edge of box. the lift top and you have access to the elements.
Jan 05, 2012 | GE Monogram ZEU30R Electric Cooktop
One of the burners does not work. Is it possible
yes,heating elemnt and the control can be chgd.to chg those pull the unit out and let it sit on the counter.remove all the screws around the stove just below the glass top.once the screws are out u can pull the top up and have access to all the components.make sure to turn the ckt breaker off b4 opening.u dont have to disconnesct the power cord from the wall if it is hard wired.
Aug 09, 2009 | GE Profile JP930 Electric Cooktop
Need to access the burner controls from underneath the top panel
visit manufacturers web site and click on support and enter model number
Dec 08, 2017 | Dacor Preference SGM365SS Gas Cooktop
I have a KitchenAid KESS907SSS 30" Slide-In Electric Range with a broken glass cooktop. I have the replacement cooktop and want to do the replacement myself as I live on a remote island. It looks like...
Problem solved. Followed the instructions given and successfully changed the cooktop.
It turned out that the front control panel needed removal in order to access the screws behind it. After that it was clear sailing.
Thanks for your help with this.
Dec 08, 2008 | Jenn-Air JED8430 Electric Cooktop
How can I open my glass cooktop (thermador GGNCV30W)
sound like you are on the right track if you have found the screws under the burner caps. some of those types has a big brass nut. some of them you have to remove the unit and access from underneath. send picture of what you are looking at if you like. good luck
May 30, 2017 | Cooktops
Cooktop downdraft blower control knob broke off
Hello
Yes their is a way, you need to unplug the power, and look for the brackes that holds the cooktop to the counter, remove those scrwes and lift the cook top, then look under the top lip and you will see small scrwes, remove those and the glass will lift, then just reverse the steps.
Hope this help!!
Eddie Rentas
Tupper Lake NY
Jun 08, 2008 | Cooktops
Jenn-Air JED8430 Electric Cooktop Logo
348 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
MARLON KELLER
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
