VeriFone VX510 Logo
A
Anonymous Posted on Sep 19, 2014
What does must settle TSYS MEAN WONT TAKE CARD
IT WONT TAKE ANY DEBIT OR CREDIT CARDS WHEN YOU SLIDE THE CARD THE MESSAGE COMES OUT MUST SETTLE tsys
frank_oboyle
Level 1:
New Friend:
  • Contributor 55 Answers
  • Posted on Sep 20, 2014
frank_oboyle
Contributor
Level 1:
New Friend:
Answers
55
Questions
Helped
72222
Points
60
This means that the batch file needs to be settled before more transactions can be made. Do a batch download and this should solve your problem. If you need more help call. Frank (775)338-6634
Kelli Sims
Level 2:
Scholar:
New Friend:
  • Expert 154 Answers
  • Posted on Jan 07, 2015
Kelli Sims
Expert
Level 2:
Scholar:
New Friend:
Answers
154
Questions
0
Helped
97324
Points
240
You are processing with TSYS and the error message is simpy saying you can not settle. You will not be able to run a credit or debit transaction until the batch settlement is completed. manually settle your terminal, then you should be able to run credit and debit cards. did you notice if your batch from either the previous day settled, if not that is the reason the terminal is trying to get that settlement to go through and it does not want you to add any sales to a settlement batch in progress, so you must settle the batch.
2 Related Answers
danielizapat
danielle yancer
  • 107 Answers
  • Posted on Aug 04, 2010
SOURCE: We have the Verifone VX510.
call the verifone number on the machine try plugging it in to another phone line
Anonymous
  • 10 Answers
  • Posted on Jul 29, 2011
SOURCE: Our Verifone VX510 printed our
This problem could have multiple causes. It sounds like you are receiving a settlement error, which are specific to each merchant services provider. You will have to call the merchant services provider so that they can look up the error message on their end and tell you what is causing the error. For example, the error message that you would receive if you use First Data would be different than the message you would get if you used Bank of America. Your terminal will not let you run any more cards until you resolve the settlement error. This is to prevent you from continuing to run cards in a corrupted batch, or a duplicate batch.
1helpful
How do I fix a Batch Erro QD-621-0108??
QD Error-basically is saying... quit duplicating. there is a transaction in the batch that is not allowing the batch to settle and it is failing, call your TSYS provider call center to have them look at the batch, either take out/ void- the transaction that is failing or causing the problem and then try to settle or have them force the batch thrueclear the data base and reset the batch number. This should fix the problem
Batch error RB-000-E0001H18000
call your credit card processor, they have to call TSYS to get them to clear it on their end as well.
How to fix settle error RB-000-E0001H18000 on a hypercom t7plus
that error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end too.
Why batch error RB-000-E0001H18000
That error RB: means repeat batch / the batch was already sent and needs to be cleared out of the machine. TSYS also needs to clear it on there end ...
1helpful
Our Verifone VX510 printed our detail report at closing last night, but the settlement failed multiple times. Now we are unable to use the machine to process a debit or credit card transaction because it...
Can you help me shop on ebay? I dont have a credit or debit card, what else can i do? Thanks.
YOu can go to http://www.paypal.com and establish an account. It can be linked to your checking or savings account or to a credit or debit card. Your choice. It is a very secure way to deal with online purchases. If there is ever a problem with the buyer then paypal will help you settle the dispute and make sure you get your product or help you get your money back. Most ebay sellers prefer to work with paypal.
Received an error message at close out RB00546E... Tech support tells me that my comuter operating system is too old to contract. Tell me to upgrade. Have a new computer coming Windows7. In the meantime,...
Would probably need the the entire error. The RB simply stands for Rejected Batch when you are trying to settle (I'm guessing with Vital/TSYS). the 00546 is the transaction number. This looks like a rather large batch. The transaction in question is the 544th transaction (the first two records to go over in the batch contain account information and your company information. So always subtract 2 from the number shown).
Without seeing the rest of the error, I can't say exactly what is wrong with the transaction. There should be a 3-4 digit number after the E in your response from the processor.
At any rate, depending on your version of PCCharge,there is a Batch Editor is included. It will be in (C:\Program Files\Active-Charge) for Payment Server or (C:\Program Files\PCCW) for Pro, and is named BatchUtility.exe. This will allow you to quickly view the batches and edit the transactions you need.
If Vital/TSYS is your only merchant account, then your batch will be named Visa1.xxx.Since it is now a rejected batch, it will be called Visa1.PCS (A regular batch should be Visa1.ENC for encrypted. Unless you are on a really old version). You should be able to open the Batch Utility, Open the bad batch by clicking find "Indeterminate" button, find the 544th transaction (if it's corrupt, you'll be able to find it rather quickly), and void it out. Keep in mind that this is not the same as voiding through the inteface, it is merely taking the transaction out of this particular batch, not voiding the transaction authorization. If it's a sale, you're authorization code will still be good (assuming it hasn't been over 30 days since you last settled). If it's a credit or void, there will not be an authorization number to worry about, and you can just dump the transaction altogether.
Make sure to take notes on the transaction so that you can run it as a post-auth (if it is a sale) after your batch is accepted. Once the offender is removed, you should be able to go back into PCC and settle as normal. You will get the message about "all indeterminate batches need to be closed first, blah blah blah", click "ok", check your totals and then attempt to process the settlement.
Good Luck and hope this helps.
Top VeriFone Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
