How do I replace color cartridge in HP 7410 all in one. I don't know where its located
SOURCE: HP 7410
I just spent over 1 hour with online support. My printer hp 7410 message says replace black ink cartridge. The message appeared when I replaced the black ink cartridge with a new one. The printer is useless while the error message is present. Support diagnosed it to be hardware problem and need to replace printer. Problem was this happened 14 days after 1yr warranty expired! The diagnostics report said that there was an open/short on Right cartridge. After closer inspection I noticed that the black ink cartridge punctured the plastic contact tape on the back! THIS IS CLEARLY A BAD DESIGN . Be very gentle when replacing the black ink cartridge. Solution is replace the broken part.
SOURCE: HP 7410 All-in-One
HP made me "upgrade" to an L7780 refurbished printer for $349. Guess I got the wrong tech support.
SOURCE: Printer does not recognize color cartridge for my HP OfficeJet 7410
Are you sure it's a genuine HP cartridge? Sometimes remanufactured cartridges aren't recognized by the printers. HP and others make them so that they have a chip inside that ensures only new genuine cartridges can be used. Try a new HP and see if that solves the problem. If you've already tried that one, then make sure the contacts in the printer are clean. If you still have a problem, then I'd say try a new printer!
SOURCE: My HP Officejet 7410 xi is showing an error
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
SOURCE: My HP 7410 will not print in color. Black
my hp printer officejet7410 made a wierd noise and now the only color that anything prints is in reds and pinks.
