I removed ice bucket in order to clean it & now cannot get it back ibto freezer. please instruct.
SOURCE: I need help fixing my
THE LITTLE SENSOR GOES UNDERNEITH THE ICE TRAYU IN THE FOAM RIGHT BY THE MAIN ICE MACHINE MOTOR. THERES TWO CLIPS THAT HOLD THE PLASTIC PIECE ON AND LETS THE SENSOR GET A TRY READING ON THE ICE TRAY.
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
SOURCE: ice maker very slow to make ice
Sir,
To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant.
I suggest you to contact the service authority.
Thanks for contacting Fixya.
SOURCE: Samsung RS2555SL Ice Maker gone nutty!
The icemaker relies on the motor to twist the ice tray about 120 degrees or so the dump the ice out of the tray. In order to get the ice to separate from the tray the force of the motor actually torques the tray against the rear plastic support (much like you would twist an old fashioned ice tray that you fill up by hand). Anyway, this puts a lot of force on the plastic elements that support the tray and they break after time. Once the plastic support breaks in the back there is nothing to get the ice out of the tray and each subsequent filling of the ice tray results in water spilling all over the ice bin and eventually leaking out the front of the refrigerator. You can order the part and fix it yourself (the part is DA61-00244A and is available from a number of websites. Total cost about $16 with shipping.
