Can you please help with this matter. Thank you
Sounds like either the hose has a hole in it, it isn't seated right, or it isn't tightened sufficiently at the connection. Most often, leaks by the connection are actually leaks at the connection and the water is running down the pipe a bit. Try turning the water off in the main system or at any valve before the connection and then tightening the connection another quarter turn. While directions caution us to be careful not to tighten too tightly, we must insure that our connections are sufficiently tight so that the water doesn't leak out. You may also take the connection off and make sure you have a layer of plumber's silicon tape on the threads and then put the connection back together, making sure it is tight enough so that there are no leaks. Less likely, but possibly, the hose may have a small hole in it. In this case, the water is likely spurting out of the hole rather than slowly leaking down the pipe.
