Tub unbalanced
All front-load washing machines have shock absorbers that are used to dampen the tub movement in the spin cycle. The shock absorbers or struts are attached to the base frame and to the outer tub and you will need to remove the front panel or the rear panel to access them. When shock absorbers weaken or become damaged, the machine will often make a loud banging sound during the spin cycle and if the symptom is not corrected, can lead to damage of other components. Inspect the shocks for signs of broken attachments, leaked fluids or a weakened dampening action and replace both shocks if worn. Remove power from the appliance before attempting this repair.
Some models of top-load washers use tub dampening straps to cushion the movement of the tub during the spin cycle. There are four straps attached to the top of the tub and to each corner of the cabinet
Also There are four suspension rods that suspend the tub and allow the tub to free float. If the suspension rods are noisy, there will be a squeaking noise during wash. You can fix this by putting bearing (lithium base) grease in the cup that each rod rests in. If it continues to squeal replace all four rods the cups come with the rods, replace them as well.
If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Lastly Washer vibration can be caused by a broken counter balance spring. Ur washer may be equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration.
By the way my advice is free cuz God is good!
SOURCE: how close can the samsung washer wf338aab be to a wall
Completely against the wall but it is recommned to be atlest 3 inches off the wall
SOURCE: how do you install a pump motor on a samsung
remove back panel and you should see the pump .remove the clamps on the hoses and there should be 3 bolts securing pump to base, remove with socket, 1/2
SOURCE: How do I replace the oring gasket on a front
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
SOURCE: i have a samsung front
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive ir spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging. This noise is heard in the spin cycle.
