I need the parts schematics
It appears that they don't care to share their schematics. User manuals are available but I can't find any with schematics. Below is a link to the company. See if you can request a manual from them.
Schumacher
SOURCE: need manual
So to this site and download it.
http://manuals.batterychargers.com/manuals/00-00-000496.pdf
SOURCE: need to charge 12v car battery
If battery is out of the vehicle, connect positive lead to positive terminal and negative lead to negative terminal.
If battery is in the vehicle, the proper way to connect leads depends on if it's a negative-grounded or a positive-grounded vehicle.
Here is a link to the manual for this charger.
Click where it says "Get This manual" (it's free).
Scroll down to pages 4 and 5 and it give detailed instructions on the proper way to connect leads and a lot more. It's a good manual to keep for future use.
I hope this helps.
http://powertool.manualsonline.com/manuals/mfg/schumacher/se520ma_se5212a_se1275a.html
SOURCE: Issues with Schumacher Battery Charger SE-82-6 -
I have the same one. The black wire from teh ac cord has a white connector that goes on the switch but there are 4 choices. I need a diagram as well.
SOURCE: need an operators manual for a schumacher SE 12 50 batttery charger
Step 1 - Go to https://docs.google.com/viewerStep 2 - Copy and paste the following link http://dl.owneriq.net/4/4a2f0b45-a67d-45e8-af4a-93de66b92ec4.pdfStep 3 - Generate LinkStep 4 - Scroll down until you see "To view now, click here."
SOURCE: need a 3 position switch for a Schumacher model se-2352 battery charger
Search for 3-position rocker switch
Use google and google image search.
Quick search shows 16 amp switches.
Probably the switches inside charger control contactor or relay.
Or connect directly to a circuit board.
The board might be bad, or relay points burned.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
