Getting only COLD water in all cycles regardless of the TEMP Switch settings. Have checked both water lines - Plenty of pressure from both Hot and Cold.
SOURCE: Our Bosch Nexxt washer uses very hot water on all
there is a mixing valve that uses a solenoid to open and close (and mix) the hot/cold inlet water based on your selection.
If you verify the correct model # I can point you in the right direction for a new valve if you are so inclined.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
SOURCE: I get a check water tap error 2 to 4 times a load
I have this problem. This code is due to restriction of water flow. In my case, we have sand in our water, and I have installed a filter between the water line and the washer. When it gets clogged, the flow is restricted and the Check Water Tap message appears. Your washer has filters on the back of the washer itself that may be clogged and need cleaning (which is why I installed the water filter between the washer & water line to prevent it from getting into the washer filter). Your washer manual shows you how to check/clean them. Also, you may have low water pressure during summer months due to lawn watering in your area that could cause this lower water pressure.
SOURCE: I have a Bosch washer wfc5301uc it is showing error code E02
Could be a faulty inlet valve, or not enough pressure to operate valve,
Remove hose onto valve, and check the water is getting to it o/k,turning off the water to the valve before you undo the hose.
Hope this helps.
SOURCE: Bosch Nexxt 100 series front load washer
You first of all need to check the pump filter.
This should be located at the botom front right of washer.
Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean.
The pump itself is directly behind the filter housing, check there is nothing stuck in the housing.
This should solve the prob.
Please leave feedback for my solution.
Thankyou.
Testimonial: "I submitted a question and got a very quick response. The response was useful and enabled me to make the repair myself. Thank-you!"
SOURCE: Bosch Nexxt 100 series washer stops at 1st spin cycle
take a look at your manual that came with your machine go to problems usually at the back and see what that says,or go to the bosch website and type in your model number its on the inside of the door.i would suspect a program fault.adrian,,,,,
