Exercise & Fitness Logo
A
Anonymous Posted on Sep 15, 2014
Display panel lights up--motor will not run
We have a ProForm Model 995 SEL treadmill. The display panel will light up, but motor doesn't run
Treadmill Repairs Brisbane
Level 2:
New Friend:
  • Expert 338 Answers
  • Posted on Sep 25, 2014
Expert
Level 2:
New Friend:
Answers
338
Questions
0
Helped
77841
Points
473
Possible motor or MCB problem .
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Feb 27, 2009
SOURCE: I need a manual for the proform 995 sel treadmill.
download manual from the link below
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/proform/manuals.d2w/report?lan=&match=exact&name=PFTL99600
sorry to say but there is no free manual on net, so you have to pay 9.69 buks to sownload the user manual.
Good Luck!!!
neo
Anonymous
  • Posted on Dec 22, 2009
SOURCE: My Proform 995 SEL treadmill changes speed
It turned ou to be a worn drive belt. Replaced and fine
maxtreadmill
John Mazmanian
  • 832 Answers
  • Posted on May 20, 2010
SOURCE: Proform 995 Sel treadmill
Go to iconservice.com click on manual input manufacturer & mode lname
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Feb 15, 2012
SOURCE: Proform 831 threadmill
Dear Sir:
You have a serious problem:
Do the following step:
1) Test the power from outlet wall.
2) Test it for ground in the outlet wall.
3)power cord test for loose cable.
4) Reset c.breaker from the treadmill
5)test the transformer for voltage input and output(primary and secondary ).
6)Power supply see if there are some component burn or loose wire or melt.
7)See if there are +5 Vdc for digital circuit(main motor board.(
8) Run the calibration software under the Hood motor is the instruction. for diagnose.
attached the block diagram.
sincerely.
ernesto cuadra
managua, nicaragua c.a.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Apr 04, 2013
SOURCE: Proform L18 treadmill display doesn't work. Incline and speed switches work but no led display
f6627a04-b106-44a9-8b92-9f8216f7b081.gifsee the diagram attached. Clean it. Test for open or faulty. Tight the connector. God bless youecb0db45-4f21-4a62-9528-93bd2d358ee3.gif
1helpful
Sticky track
see the video and proceed. You must lube evey 150 miles aprox.lube the rollers bearings too,. God bless you
Proform power 995 treadmill incline button not responding after initial calibration
I suggest to RUN again the software calibration, and read carefully your instr. manual for to remember anything
However see the diagram attached, and lube the gear, shaft of the elevation motor, and tight any connectors or plug ,clean it.
God bless you
2helpful
Proform 995 sel will not incline
Try calibrating the incline.
Start the machine. While the machine is operating, press and hold the incline up button. Remove the safety key. Now replace the safety key. The treadmill should go to full incline, then back to the bottom. Once the cycle is complete, the machine should work normally.
2answers
Manual for proform 995
Hi there. You can go here and enter the model number In the model number box and download a manual for free.
http://www.iconservice.com/CustomerService/manuals.do
Good Luck, Tim
1helpful
1helpful
2answers
Pro-form 995 SEL treadmill - motor runs for .5 sec. then stops. All functions on console are active. Ran thru all diagnostics with I con rep on phone up to the point where she instructed me to remove the...
Hello there, You have a bad motor control circuit board. This will be the board that the motor connects directly to on the other side of the belly pan. Be sure to check the pictures in your manual to verify you get the correct part due to the cost variance.
You can find parts pricing and the manual at iconservice.com and enter pftl9960 in the model number area.
Good Luck! Tim
Good Luck!!!
neo
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
john h
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
