Kenmore Bottom Freezer about 10 years old.
Refrigerator running but not cold. Freezer section plenty cold. Doesn't matter where the thermostat is set. Nothing blocking vents. No air flowing from vents though. Light goes off when switch is pressed.
I'm thinking thermostat switch or refrigerant coolant - yes? If it's the coolant I'm very handy and feel I can fix.
The fridge gets its cold air from the freezer through a vent
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp .
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
