The listing for bbc red button service only shows 'watch' or 'record' but can not watch what is showing now,or set it to record
SOURCE: I can't figure out how
You can't. The unit doesn't have dual tuners, so your stuck with just recording one show at a time. Sorry.
SOURCE: Humax DRT800 DVR recorder has no sound
Loss of sound is often a problem with the SCART connections. The SCART may not be pushed in securely, or if the SCART is old the pins may not be good. Check SCART is securely in, or try another SCART lead.
SOURCE: I ws using my humax to watch a programme, when the picture froze.
It can sometimes happen if the signal level drops & the TV digital decoder cannot pick up the strength of the signal when the transmission is back to normal. Switching on & off again resets the processing again. This is a similar effect that can happen with cable or sky transmissions also, it acts the smae way as sometimes having to re-boot your PC if that should crash. It is not necessarily a fault with the TV.
Testimonial: "Sounds logical, but why did not the TV digital signal also crash? "
