My machine is coming up with an error when I try to start the wash cycle. The machine is a F&P MW511 Pride and the lights that are flashing are 5 (green) and 8 (spin light) red on the panel. Please help by telling me what error this represents, I would prefer to see if we can fix it before forking out for a repair if possible. Thank you!
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
SOURCE: Washing machine wil not fill - tries several times then stops and all lights except 4 go out
That would be the balance switch, should be located rear right under the main board. over time the switch becomes jamed in the on position and the machine always thinks its off balance. $4 to $10 for a new one.
SOURCE: Hi. I need some info on the fisher and paykel
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
There should be little letters below the lights that tell you what each means when they are illuminated. I would start there and additionally the owner's manual.
In the end we got someone in to look at the washing machine and it was the controller module which we have now replaced.
