Is there an online instruction book
SOURCE: how do i set the
Hi an_stocker0,
There is two pulls to set the time and date .First pull is for the day / date wind it in order to choose the right date number and second pull is for the time wind it until the desired time comes out. For better understanding follow this link for more information and instructions below. Feel free to ask whatever the results.
http://www.armitron.com/docs/Automatic%20Manual.pdf
Hope its may helps;
Regards,
VOTIT
Testimonial: "thanks "
SOURCE: do you have directions for
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron
Wristwatch, what exactly would you be experiencing? cause I only put
info on how to set time and date on the Watch.
Please see below steps:
See
Steps below:
*Setting the time*
I
hope that this will be of help regarding your query on how to set the
time on your Armitron watch, I
also included the setting of the time and
date just for further details.
Thank you for choosing Fixya,
mvincentc
SOURCE: Watch instructions for Armitron m721 (49/1009 GP)
Hi mandardani,
You can change the time and day of your Armitron watch by following the steps below.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
