What could cause this loud sound?when I start up my gas lawn mower?
SOURCE: Yard Machine MTD push lawn mower won't start
Sounds like you need a complete tuneup. Start with the carb. then clean all coil contacts, air filter and this will start you in the right direction. Good luck.
SOURCE: Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
SOURCE: ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
SOURCE: Can't pull my starter rope on my Lawn Mower-seems locked up---
If its a Murray lawn mower like mine, it may be using a Briggs and Stratton engine. it sounds like the spring is broken or out of its track You can find the right part which is called a "pulley/spring assembly" by locating the model number of the engine. There are instructions on how to find this at: http://www.briggsandstratton.com/maint_repair/repair_parts/
SOURCE: lawn mower husqvarna problem
I have an XT721F self-propelled, auto choke Husqvarna mower. The first time I used it this season it ran for a short time and then just quit on me. I have since emptied out all of the gas and have replaced it with high octane 91, and have also added Seafoam to clean out any other issues. I mowed two weeks ago with no problems and went to mow again today and only made it through 2/3 of my back yard and the mower stalled out on me again. What's going on?
Hi hazel zelisko, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Describe it
