My mower is a rear transmission. When it gets in a little bind or when I raise the front wheels to turn it sounds like the blase may be hitting the deck. There are no marks under the deck indicating this. What else could it be? No mower shops can tell me.
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
SOURCE: Have a 3 year old 6.75hp Craftsman SP mower. Hit a
Some things to try:
Keep the mower on a smooth surface - concrete or asphalt - does it still clank & stall?
If it stalls on concrete, try loosening the gas cap.
Remove the plug, lift the mower and rotate the blade, is it or the motor shaft bent?
Gary
SOURCE: clipped grass tends to get clogged under the blade and not fill the bag
there is different blades do you have the right blade for bagging?
None of these come near answering my question
This may not be the exact mower. I do not know the numbers.Add a Comment
