Microwave Ovens Logo
J
Jack shr Posted on Sep 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a kenmore elite micro hood combo showing a TE error code. Anyone know the what this error code indicated
Stopped working and showing error code TE. Manual has some error codes but not this. About two years old
Ronald Rissel
Level 3:
Master:
  • Microwave Ovens Master 715 Answers
  • Posted on Sep 20, 2014
Ronald Rissel
Level 3:
Master:
Answers
715
Questions
Helped
258785
Points
1075
Need a model number.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
5 Related Answers
Anonymous
  • 413 Answers
  • Posted on Jun 11, 2008
SOURCE: Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
Anonymous
  • 1447 Answers
  • Posted on Jul 10, 2008
SOURCE: I have have a 10
Hi-
Thats a microwave relay error that you are getting, pls refer to this link, this might Help you with your issue just click HERE
Keep us posted.. Thanks for using Fixya!!
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 23, 2008
SOURCE: I have an error code
Quoting another board:
Sears Kenmore Whirlpool LG 721.63683300. F-9 on this microwave IS inverter related.
There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing procedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c.
f9 model 721.63764300
Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 18, 2008
SOURCE: Looking for manual on how
You can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
A Miller
  • 8404 Answers
  • Posted on Sep 27, 2009
SOURCE: My Kenmore 665.60622000 Microwave/Hood Combo just
Check the fuse inside the cabinet on the floor near where the power comes in.
1helpful
What does an F=1 code mean?
Convector element has failed.
Time for a repair.
E-1 error on my Kenmore microwave, will not work?
https://homeguides.sfgate.com/cuisinart-bread-maker-error-codes-13409633.html
Error code ERROR 1 presents on Kenmore Elite countertop microwaves with model numbers 56561582011, 16755, 56561584011 or 56561589011. ERROR 1 occurs when the unit has not received enough power to undertake a sensor cooking operation. Sensor cooking is a feature of Kenmore Elite microwaves that adjusts the temperature and cook time of dishes contingent upon information received by sensors in the microwave. In order to perform this function, a microwave must be plugged into a power source for at least five minutes previous to doing so. Thus, ERROR 1 indicates that the unit has not been plugged in for a sufficient length of time.
Kenmore Elite Microwave Model No: 79080373310 giving E-11 error code
I do not know what an E-11 code is on that unit. But the fact you say no buttons are working gives me a clue that you may have a bad touch panel. Could be a Goofed up Microprocessor on the board. A Lot of units will give a code for a bad pad. If an air pocket in a pad colapses, the microwave thinks you are pushing and holding down a pad, so it will give a error code. An E-11 code may mean a bad touch panel on your unit. Try to unplug the unit, give it a minute and plug it back in, try to set the clock first and see what it does. When setting the clock try all of the number pads and see if they all respond. If one doesnt that mey be your bad pad. Or if a number comes up on its ownwithout pushing it, that pad could be shorted.
Have a TE code showing on my kenmore elite microwave hood combo
At some place I saw that the TE error refers to the touch panel.
If you go to http://www.searspartsdirect.com/ and enter your full model number you can get parts list and buy parts and even get repair advice.
Link below shows how to replace a control panel on some model of microwave oven. In the video you will see a ribbon cable being removed. You might want to wipe the contacts of the ribbon with alcohol and put it back in to see if it helps with your problem.
F3 error Microwave oven control panel replacement
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
1helpful
I have a TE Error on my Kenmore Elite Microwave... what does it mean? It won't do anything... I've unplugged it to see if it will clear... nothing...
The cause of the TE error for us was grease/gunk on some exposed pins and flex connectors (communication bus between controller and keypad) that was interfering with communication with the keypad. Resolution to TE error: Remove the keypad / control board from the microwave. There are three screws on the bottom at the front to remove. Once those are removed, the keypad is held on by clips. Slide the entire keypad to the left and it will come loose. After it is loose, carefully remove all the wired connectors to the microwave. Lay the keypad face down on the counter and look at the control board. The control board is actually seperate from the keypad and connected via two thin flex strips with many small contacts (like a nintendo game connector) . Our flex strips were covered in grease from the hood fan operation. Carefully clean the strip and the connector (with a felt pen if you have one) and resassemble. This resolved the issue for us.
1helpful
Microwave door shut, but interior light is on - micro won't work
Yes. One of your door switches is not working. It could be an alignment issue or a faulty switch. There are actually 3 switches in the door latch area.
Eric
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
