Pride Victory 3 Wheel Mid-Size Electric Scooter  Logo
A
Anonymous Posted on Sep 09, 2014
I have new batteries two weeks old. They now will not charge properly. could it be the charger? This is on a victory 3 scooter
I bought this scooter used. It ran great for 2 months. Then the batteries sterted failing. I bought new batteries which worked great for a couple weeks and now they are not charging all the way.
Colin Taylor
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 347 Answers
  • Posted on Sep 10, 2014
Colin Taylor
Expert
Level 2:
Mentor:
Answers
347
Questions
Helped
91281
Points
545
Did someone qualified tell you that you needed new batteries?. I would go back to the battery supplier & go from there.ALSO,if you still have the old ones can they be tested too.Ask them,i hope this helped.Colin
5 Related Answers
mmb_safe
Mark Brown
  • 168 Answers
  • Posted on Mar 08, 2014
SOURCE: New batteries, fully charged, still wont work
I will ask but don't take offence, so many people overlook the obvious, have you checked the free wheel lever/s are not set to free wheel (if it is the scooter will be relatively easy to push forward or backward) if set to free wheel then move lever/s to drive position
http://www.pridemobility.com/pdf/Owners_Manuals/US_Scooter/US_Sonic_om.pdf
this is a link for the sonic scooter user guide, not 100% sure that it is the exact one or not but it should show you were to find the free wheel lock on your scooter it is in this guide and I would be surprised if it is not the same as yours. Hope that helps. Mark.
Dan Hudson
  • 119 Answers
  • Posted on Nov 27, 2008
SOURCE: scooter is dead
Are you sure your charger is working? Is the free-wheel lever engaged? Also the charger has an inhibit line, it will not run when the charger is plugged in.
Anonymous
  • Posted on May 13, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
gewiz
Rob Hill
  • 1480 Answers
  • Posted on Oct 01, 2009
SOURCE: will not charge
then I would first chec kthe connections that the battery charger connects to, check the batteries on another scooter .
Regards
GeWiz
littleone121
  • 23 Answers
  • Posted on May 06, 2010
SOURCE: i have a old pride victory 3 scooter working well
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
Want to see why my batteries wont charge. Product is new !
Is the charger getting power? Is the power reaching the battery pack to charge them? If you answer yes to both questions then something has to be wrong with the battery pack.
I can leave it plugged in for 24 hours and not have a full charge. Is this the batteries or the on board charger
There are a few things to consider with this type of problem.
How old are the batteries. When did you last have them tested. Is the charger output ok on load (test with an amp clamp type meter). is the charger the correct one for these batteries, small output chargers take longer to charge big batteries. Are all connection tight on batteries and anything to do with the charging circuit. Plug and socket type connection do fail on poor connections. Check voltage on batteries when on charge and off charge to see if the charger voltage is getting through to the batteries.
Pride V10 ****** wont hold a charge. It runs out of power afetr 10 minutes,
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger...
Regards
Rob
www.gewizrepairs.co.uk
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Hi i have a sony dcr-pc3 my wife bought it in 2000 and it never holds a charge the longest we get is about 10 minutes we bought a new battery and have just bought a new charger same old...
Well if you have bought the right battery and the proper charger this sounds very odd, did the amp hr and every say the same details on the battery & charger as the old one? when you charge the camera how long was it till you used the camera? as Sony cameras lose around 30% charge per week, I know because I have a Sony still camera and movie, both lose charge, my still camera goes flat in 3 weeks after a full charge with no use at all, so they are never good bits of equipment with batterys.
2answers
My scooter says its fully chrged but its not. this happens once in awhile, any suggestions?
your batters have lost their charge at some point in time. These gel batteries, if they ever set for a long time with out recharging, or arn't recharged daily with daily use, will seem to be charged. but arn't. their expensive but I've seen batteries last over 5 yrs when taken care of properly.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
