SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
They have helped me several times.
Hope this helps
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
