1st fridge did the same and they replaced it after 1 year. 2nd fridge started same problem after about 18 months. Had it fixed (R600) in March this year. Same thing happened 6 weeks ago. I unplugged it for 48 hours. Helped for about a week for the leak and then started again. Noise has also started now again.
SOURCE: Water tank inside fridge for water dispenser leaking
peah, I had a couple of these tanks leak. I think they had an issue with this. The last one I had they had a kit where the substitued coiled tubing with 2 john guest fittings to replace the tank. This solved the problem. The part number I have for the tank is 4838jj1003a, you can get it at http://www3.sears.com/ for 17.95. I don't know if they will send you the tank or kit. You can inquire. Catriver...post back.
SOURCE: Fridge noise
Some larger refrigeration units have fans, but typical domestic ones usually do not, only inside the fridge/freezer compartment as such, and is used to force cold air inside the unit to help keep the contents cold.
As for the fire risk, anything electrical usually have a certain amount of risk as far as fire hazards are concerned, but certainly a lot lower then say an electrical heating element or similar device.
The noises you describe usually come from the pump itself, and i can not say if your particular fridge would have any type of fan on it not knowing the model, makes it very difficult to give any sort of prognosis - based on specific models and their typical faults/noises.
Unplugging the fridge simply stops the pump, and the noise usually returns in a minute or two as you have described, simply because the fault/noise is still there.
Pumps and repair work can be expensive, especially if the fridge is an older model and based on the average that most electrical units have a typical lifespan of 1 - 5 years depending on the quality of manufacture.
Look at it this way, a good basic unit costs anywhere from $800 - $1,500 and some of the more expensive models start from around $1,800 + ( Prices are based on Australian models and are quoted in Australian dollars )
Ok so lets break this down a little, i buy a new fridge for $1,000 and it lasts approximately 5 years, this is not expensive if you look at the cost per year which is approximately $200 / year.
Compared to the cost of repairs, typical service has a call out fee, plus parts and labor which can run into literally 100's of dollars. I guess what i am saying here is, they do wear out in time, due to fair wear and tear, and planning to buy a newer one every few years, is not such a bad idea - considering when you weigh up the possibilities of having purchased a device that can keep food cold for up to 5 years ( and in some cases longer ) for around $200 / year, planned replacement models make sense in the long run. A good way to know, is by looking at the warranty and plan to have a newer one to replace it within 12 months of the warranty's expiration, with the added bonus, you can now plan to sell the one you currently have for a few hundred dollars to help with the cost of getting a replacement.
Trust this helps you out a little, and please take the time to rate this answer, thank you.
SOURCE: Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
SOURCE: Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
I was able to solve this problem by doing the following:
1) Carefully (because there may be sharp metal blades in this area) reached into the upper left compartment of the icemaker and pressed down on ice cubes that seemed to be lodged there and were protruding slightly above the slots they should have been passing through.
2) Press down on the cubes, forcing them through the slots and into the cube container below
3) Lift the metal arm, remove and completely empty the ice cube container
4) Return the ice cube container to the freezer, making sure it is seated properly
Close the freezer and wait until the ice cube maker begins to make new ice cubes. The sound should stop in around 10-15minutes.
