It has always worked, but now when I turn it on it just beeps continuously and then turns off No steam produced.
SOURCE: Rowenta Steamer
I am not sure what the problem is, but Rowenta recommends that you use only clear or filtered drinking water only. Make sure to remove the reservoir and use the burst of steam to empty it out completely. When cool, access the steamer drain hole and fill and flush the tank over the kitchen sink or use the cleaning kit following the instructions. After a few of these use and purge cycles the system should be clean in a few weeks.
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
SOURCE: Hot hose but no Steam
Don't know this machine but if it has brass jets on the head stick a pin or a needle into them twisting while pushing in and out, some times these jet block up. other wise undo hose and blow through it hope I have helped in some way.
SOURCE: MY ROWENTA 1550W UPRIGHT STEAMER NO LONGER
I have a Rowenta garment steamer. It will turn on but no steam comes out. Does it need to be cleaned from the build up of iron, etc. from the water? If so, how do I go about this?
SOURCE: I have a rowenta garment steamer is7850. It
Vinegar is great for any mineral deposits for coffee pots and irons.
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
