F21 error code
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
SOURCE: Kenmore HE2 Plus error code F21
F21 Is a slow or long drain.
Things to look for kinked drain hose,
Plugged or obstructed drain hose, Possible pump filter screen clogged,
Least unlikely is a drain pump failure.
The pump filter screen is
the most common it gets plugged with lint, coins, hair etc. It can be
cleaned by the owner however is is a very dirty messy job and if you are
not very careful you can end up with water everywhere. If you want to
attempt it let me know. If there is anything else I can do to help
please let me know.
SOURCE: Washer won't drain completely. All lights flashing. F21 code is flashing.
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
SOURCE: kenmore HE5t f21 error code
SOURCE: how to fix F21 error code on a Kenmore Smart Wash
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
