Google images has a way to search for similar images on the internet. If you put your picture on the internet, for example, on your own Facebook or other page, there is a way to search.
However, you have placed your question in the Food Mixers category. Is it a portable cement mixer or something else, perhaps spelled differently?
Is there power in the wall socket. Check with a lamp?
Does the motor get warm when plugged in for a while?
Does the motor have a starting capacitor? Look for a metal tube on the side an inch or so in diameter. Those are AC electrolytic capacitors that are a common failure item.
Put an ohmmeter across the two pins on the plug, on the mixer,,not the earth one.and turn the switch on.you should get a reading,plus it will change as you turn the switch to different settings.if no reading,suspect broken wire in plug,or mixer windings burnt out.try in a different socket
There ate two ways to fix this problem, but first there is the matter of understanding what is leaking. The oil you see leaking is actually a food safe vegetable based gear grease. The grease separates during heavy use (years of service) or when the mixer has not been used for an extended period of time. (months or years) The recommended way to fix the problem is to do a full tear down then clean then add new grease and a new gasket, cost (By Kitchenaid at a KA service center) around $140.00 US + or -, It involves shipping and around ten days in time. The second way is kinda simple and does not cost anything. Get a towel, thick and soft to protect your finish, get your wife or husband, get an extension cord, spread the towel out on an open counter top, plug the extension cord into the outlet, turn the mixer upside down on the towel, have your significant other hold the mixer by the base while you plug the mixer cord into the extension cord, turn on the mixer no more than 2 or the second click on the speed control switch / lever, hold the mixer upside down like this while the mixer is running and keep it running for at least three (3) minutes, turn the mixer off and turn it right side up and turn on again for two minutes, then do it again two or three more times, upside down for a couple minutes then back right side up and so on and so on, after about 15 minutes stop. put everything away, you are done. What you have effectively done is re-mix the grease and it should be good for another couple of years. When it starts to leak again re-mix again. Or send it to KA for the rare and unique opportunity to spend a hundred bucks that you don't' want. hope this helps. By the way if you get some drops in your mix it will not hurt anybody. But you do not want to eat a great deal of it or you will require the use of a laxative afterwards.
You can try moving the lever slightly up or down while moving it forward to see if this will free it it or make a difference. Otherwise, the spring inside may have snapped or the speedlink cam may have came loose or broke. Either one will require the top end assembly to be removed to replace these parts.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Using the tilt release switch, tilt the head all the way back. This will expose a large screw inside the hinge which you can turn both ways to either get the beater closer or further away from the bottom of the bowl - can't remember which way is which, though. (I had the exact opposite problem: the dough hook was grating on the bottom of the bowl.)
