Whirlpool Calypso GVW9959K Top Load Washer Logo
K
Kimbo Jones Posted on Sep 04, 2014
Why is only the stop button working?
It is getting power but only the stop button works
6helpful
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
11helpful
2answers
My nokia x3 buttons have stopped working apart from the power button can you help me resolve this please
my nokia x3 buttons have stopped working apart from the power button can you help me resolve this please. The beep sound is present while navigating the keys.
3helpful
Remote control power button and stop/play/home dont work
open the remote clean with petrol
or ony from dry cloth
thare was a corben in that key becouse that key are more useable so carben
5helpful
How do you override the ink level gauge on a canon mp630? It has a stop button but no reset button.
Hi you can try this may work.
In service mode.
Put Stop/reset 4 times orange => reset waste ink.
Put stop/reset 8 times orange => set level ink.
And try this.
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
For me, it worked when I did this:
1) With the printer powered off but connected to a power source, press and hold the Stop/Reset button for 4-5 seconds.
2) Without letting go of the Stop/Reset button, press and hold the Power button. Then, press the Stop/Reset button two times without letting go of the Power button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
1helpful
Printer won't recognise cartridges UO51
Hi there
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Power off printer
Release power button
Wait 20-30 seconds - our LED showed Idle
Power off
Next time the printer is started the waste count will have been reset.
Power button stopped working and no remote
you can get a programable remote to get around that.
12helpful
ERROR 5800
1. Turn off printer.2. retaining button Stop/Reset (red triangle in the circle) press button POWER - indicator it will light up with green color.
3. let go button Stop/Reset, continuing to hold POWER.
4. press button Stop/Reset 2 times, while holding POWER button, after which you will let go all buttons.
5. when indicator is lit BY Solid GREEN - press Stop/Reset 4 times! (this is the key)
6.turn off printer by POWER button, then turn on.
7. You should be set. If it didn't work, try it again, slowly. It WILL work!
18helpful
4answers
Canon mp160 printer E5 flashing error?
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button 4 times.
The above will get you to Service Mode (and clear the Waste Ink Counter if you wish) and is supposed to work for MP160 also.
Caution if your waste ink pad is full you could overflow if ignored.
Some of the new carts reportedly have fuses which blow if the ink gets too low, denying any further refilling.
To use refills, you will probably have to turn off your Status Monitor.
Go to your printer's Maintenance section.
Scanner not working
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
