Hello, I could help you through this website or email replace your belt. You can do it fairly easily. Below is a post I made about a repair I just completed on my dryer and I had to remove the drum and belt and put them back on. Belt is easy to replace. Message me back if you need some advice.
I made a vibration repair Oct 20, 2021. I have the exact same Blomberg DV17542 dryer. It was making a horrible vibration sound while empty and full. The top panel was vibrating loud but I knew there was something internally wrong with it.
I purchased a rear bearing and 4 new frictional glides(where the drum rests on at the front). I took the dryer apart, it was fairly straightforward, removed the drum, changed the rear bearing and replaced all 4 glides. I figured this would fix it....but no! Was disappointed hearing the noise again.
I figured it had to be the motor or the blower fan. I inspected the blower fan from the back without having to remove it and bingo! I could see lint or something else inside the blower wheel.
I used needle-nose pliers to reach in and pull out what was inside. I pulled out a fabric sheet covered in lint, and when I pulled that one out I could see another behind it. I pulled the second one out, vacuumed the fan, and made sure it spun freely and wasn't damaged.
Turned the dryer on and could hear a pin drop it was soo quiet. Problem solved. Any questions let me know.
I SEE NOBODY ANSWERED, I HAVE SAME PROBLOEM BUT FOR MODEL TFA 7239
I see this is from forever ago, never mind.
