Hi
After putting a load in the machine (w123) on program 4, it washes but stops at rinse. Then the programmer will spin around clicking.
Is the pcb dieing ??
regards
Does the water empty from the machine? if not you will more than likely have something trapped in the pump. the best thing to do is run the grey outlet hose into a bucket, this will empty the machine. then tilt machine back (make sure it wont fall) then remove the plastic kick plate on the front bottom, behind this you should see the round plastic filter this will unscrew and pull out, you may need a couple of towels put on the floor as there is usually water left in the pipes. clean any debris and screw filter back in, should only need to be hand tight. replace kick plate and then give it try.
hope this helps
kj
REMEMBER MAKE SURE POWER IS OFF BEFORE CARRYING OUT ANY WORK.
hiya
to reset the programs you have to make sure power button switched off, then turn the dial to a black dot on settings then switch power on. the machine should flash a few times then switch it off again, select program, and then turn back on.
this should solve it, if not there is a fault on the machine which will be indicated by a series of flashes by the doorlock light.
hope this helps
please dont forget to say if it helped thanks
clicking constantly how do i reset program settings
