Dell 1210S Projector Logo
A
Anonymous Posted on Sep 02, 2014
Why is the bulb light shows to change and it has new bulb?
The bulb light is on to change and I have changed it and it still has the light on to change the bulb.
xalint1
Level 2:
Sergeant:
  • Expert 152 Answers
  • Posted on Sep 04, 2014
xalint1
Expert
Level 2:
Sergeant:
Answers
152
Questions
0
Helped
82217
Points
525
I dont know if you skipped this step but you should reset the lamp usage time by selecting "Yes" for
Lamp Reset in the OSD Lamp tab. Page 48 on the instruction manual.
I have a 2006 Nissan Altima, changed the light bulb and checked the fuse, the light is still not working
Do you have a multimeter? If so,
  1. Put the meter on Ohms and check that the new bulb conducts. It should show a few ohms. If it shows infinity (same as the old bulb), then the new bulb is also bad.
  2. Put the meter on Volts, turn on the lights, and CAREFULLY check that there is voltage at the socket.
If you don't have a multimeter, try another new bulb in case the other new one was bad.
Multimeter source:
Search results for multimeter
The cheapest ones on this page are adequate for these measurements.
2answers
How to change headlight buld 07 dts
owners manual will show you how replace headlight bulb.but wear clean gloves when handling and installing new head light bulbs. because oils from your fingers or hand could cause new halogen bulb over heat blow out besure wear clean gloves.
Change side light bulb
most operators manuals show how to change the major bulbs
no tall, just the ones for safety. did you read your oper. guide.
if its not there its in the FSM or at all data.com
both manuals are here. $4 day pass..... hint/?
https://suzukipitstopplus.com/Category/2-suzuki-vehicle-information.aspx
side bulbs, not exactly sure what you mean there.
my 04, page 5-51 in the op. guide says, remove the 2 lens screws
and and whole assy, pulls free and rear has socket and twist it and bam. its out.
but they move them to the Headlight assembly
so in that case, you pretend its a head light access.
i goggle for you and hit 1 was.
Your owner manual will have some instructions.
-Open the hood
-From the engine compartment, remove the black rubber boot
the boot , is the access port, read the manuals ? they cover this.
-loosen the little wire clip (or parts to access HL or side light)
-remove the bulb and unplug it
-Plug in the new bulb and install the new one in reverse. The new light bulb will only fit one way
4helpful
HOW DO YOU CHANGE THE BULBS OF THE FOG LIGHTS?
The fog lights on most vehicles sit directly underneath the headlight bulbs. The ballast and wiring work just like the headlights, so changing them takes not much time. The procedure to change the fog light is as follows:-- 1) Open the hood and reach down underneath the headlights to unplug the electrical plug from the fog light assembly. Squeeze the top of the release tab and pull the connection off the bulb's ballast. 2)Turn the fog light counterclockwise to remove it from the fog light housing. 3)Install the new fog light bulb.Then connect electrical plugs properly. 4) Test the fog lights by turning it ON. Thanks. you can rate this solution and show your appreciation.
1helpful
How do u change a bulb in the fog lights on a
2004 Verona: how to change the brake light bulb in rear...
I just replaced 2 break light bulbs in less than 10 minutes on my 04 Suzuki Verona.
First lift your trunk lid and go to whichever side that needs replacement. There was a pull down attachment that gives you access to the whole assembly.
When you have access to the assembly locate the 2 top bulbs which will be for the brakes. Turn the plastic piece which holds the bulb counter-clock-wise to get to the bulb.
Pull out old bulb(you may have to twist it slightly). I bought a replacement pack which came with 3 bulbs(#1157). Then insert new bulb into socket until firm.
Then put it back into the housing and turn clockwise to lock it in.
Then repeat the same process for the next bulb and your good to go!
If you are having any kind of difficulties with it your owners manual shows you how under bulb replacement.
Changing high beam and parking light bulb any
Buy, ($20 at your local auto parts place) or flip through the Chilton Manual for your car, it will show you the exact steps.
2002 BMW 318I showing one reverse light
simply open the boot & remove the blown bulb & replace with a new one. the bulb is just a half turn holding in there so turn it anticlockwise & it should pop out.
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
