My laptop is running Windows 8 Pro 32bit. I really hope someone can help me sort this because I have been on the sick now due to health problems.
SOURCE: Can't install a driver
i've lost my driver cd for my asus wl -167g, can i download it for free?
SOURCE: asus p5pe-vm series motherboard driver wont work with windows 7
Windows 7 is still in the beta/testing stage from what I remember.
If you go to this page courtesy of ASUS:
http://support.asus.com/download/download.aspx?SLanguage=en-us
In the search box type in your motherboard p5pe-vm and click on P5PE-VM related files for download
It will come up with a seperate window that will ask you the OS that your installing and windows 7 is not an option which tells me that drivers aren't available for your motherboard just yet, it may down the line once windows 7 becomes publicly available.
SOURCE: i installed windows XP on my Asus p4p8t and the
I'm thinking that you might have to install the chipset drivers, also.
Because the sound is part of the motherboard, they will be needed.
SOURCE: ASUS P5GD2 Deluxe motherboard with no sound
This is a known isue and ASUS is working on a sound driver for the chipset. Keep checking their site for driver updates. The board should all install with Windows 7 except for the sound drivers. Some people say they can install the vista driver and run it in vist or xp compatibility mode. The other thing you can do is pick up a cheap $20 Win 7 compliant sound card till the chipset driver issue is resolved.
SOURCE: internal microphone problem
check the mic settings, sometimes it is not sensitive, boost the mic settings and try it again. it should work.
go to volume settings and check and advance settings for the mic and from there you will see the boost settings and other recording tools as well
