SOURCE: My LG TROMM (WM1812CW) does
This code means that something is blocking either the water drain pipe,
pump filter or the pump itself. I had the same problem and removing the
filter (as recommended by LG) did not help. It turned out I had a piece
of debris stuck in the pump propeller itself and consequently the water
would not drain and the wash would not finish, prompting the error.
This is what I did to fix the problem.
1. I removed the cover on the left bottom corner and the removed the filter and unhooked the little rubber tube (drain).
2. I removed the pump cover (lower left corner of the washing machine) and unscrewed 3 screws holding the pump from the front.
3. I disconnected the power supply and removed the back panel (attached with 4 screws)
4. Disconnected the two hoses (one black, one gray) from the pump.
5. Disconnected the power supply to the pump (I had to cut a plastic
tie holding the connector in place in order to bring the connector
closer so I can disconnect it).
6. Removed the pump by pressing a little tab that was holding it from the back.
7. Once I removed the pump from the washing machine, I took three
screws out of the pump motor, gaining access to the propeller. This is
where I found a little piece of plastic. Apparently propeller couldn't
spin because of that obstruction.
8. I put the pump back together and attached the hoses. This is easier
to do when you have the pump closer to the back opening of the washing
machine.
9. I then connected the pump power supply connector, locked the pump back in its place and replaced the screws.
The total repair took less than 45 minutes. The hardest part was to
remove and replace the drain tube springs, because I did not have the
right pliers (You need decent size pliers or plenty of strength in your
hands to squeeze the metal bands).
The tools you need for this repair are:
a philips and flat screwdrivers, large pliers and a sharp knife (to cut a plastic tie)
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
SOURCE: how do i clean the filter on an LG Tromm front
The pump filter is accessed via the small hatch at floor level. It can also be behind the kick plate..Unscrew the filter and clean. It may be very badly clogged with whatever is left in pockets. Remember when the filter is removed the water will drain out..Also, check that coins haven't jammed the impeller. Leaning the machine back against the wall will stop the last of the water from draining and will allow better visual inspection...Good luck...Nomess
