SOURCE: i cannot get the list
on the bottom of the unit is a small hole for resetting the unit. Take your stylus, unscrew the pointer end and use the smaller end of it to press into the reset hole. Let the reader reset and you should have your books. Kindle has had this issue for some time with the reader that came with the free ebooks. The solution was a simple one to fix.
SOURCE: My kindle will not delete a book after I have
If you've already tried deleting the book on the kindle itself, have you tried plugging in the kindle (to your computer), navigating to the Documents folder inside and deleting the actual book file?
SOURCE: deleting a book on kindle
go to home tap on edit. then there will be minus symbols next to the names of the books. tap the minus symbol next to that particular book. now hit the done button. the done button should be located where the edit button was. now go to the book store, search for your book and now you can retrieve it.
SOURCE: hard reset kindle fire hd
I'm assuming you bricked your KFHD? if so, you're going through a bootloop? try booting into Safe Mode by holding both volume buttons during startup. Then :
SOURCE: how do i bypass the parental control on a kindle fire hd
Either enter the parental control password or factory reset the tablet. Power off the tablet, press the power then press and hold power and either vol up or vol down to get the boot menu. Choose the factory reset option.
