Do you have belt tensioner assembly diagram21 hp 46 inch cut?
SOURCE: I need a diagram of the deck belt on a huskee 46
Go to http://www.searspartsdirect.com/partsdirect/index.action Then enter your model #, search, then scroll down to mower deck. There ya are. Dwain
SOURCE: Huskee jerks while going forward
Go to... http://mtdparts.arinet.com/scripts/EmpartISAPI.dll?MF&App=MTD&TF=Empartweb&Lang=EN&searchDB=MTD&loginID=MTDCon&LoginPWD=&xmlPostDest=http://www.buymtdonline.com/webapp/wcs/stores/servlet/processShoppingCart_10101_19502_-1_19502 Enter the brand (Huskee) and model number, not the one you listed, but the one under the seat... hit search and click on illustrated parts, then click on Mower Deck. That will show you the routing and belt number.
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
SOURCE: I have a Huskee Supreme Model # 13AX605H730. I have
According to MTD Parts Lookup:
The correct UPPER belt (referred to as the PTO belt and runs from engine to deck) is part # 754-04122 (Also available as 954-04122...in which only the packaging of the part makes the first digit of the part number change. The two belts are identical.)
The correct Description is:
[ Belt, V-Type, A x 90.24 ]
What that means in plain English is that this is a 1/2 inch wide V-Belt with an Industry Standard "A" cross sectional profile. The more important info would be that it's 90.24 inches long.
As for the "Deck Belt" (the lower belt that runs only from blade to blade to blade) it is listed as part #754-0349 or #954-0349 (again, identical belts, different packaging).
A very common problem we see in my shop is that the front pulley (the one directly attached to the engine) shows signs of separation at the weld and the grovve of the pulley becomes wider, therefore making the belt "act" like it's longer because it runs deeper in that groove.
Reply by using the "Add Comments" section if you need any futher info. I'd be glad to offer other possibilities for these symptoms you've described.
Hope this helps,
Dolf-
