My dishwasher just quit mid cycle. (still has water in it) It is a whirlpool partner 1. I checked the breaker and it wasn't tripped... but i reset it anyways. When I tried the dishwasher again it worked for a second and turned off. I have done reading about the thermo fuse but can't find it. Not sure how big of a problem this is.
Dishwasher is 5 years old.
Thanks,
Dale
I hv a whrilpool quiet 2 dishwasher it will
not drain properly . whats wrong .
I am having the same issue with mine. The house circuit breaker is fine, we reset it just to make sure. Other items that we plug into same outlet come on just fine. Just appears to be no power getting to the dishwasher itself since it stopped midcycle.
Doubt that; sounds like you have an electrical short. If breaker will not reset it is due to a direct short. Leave breaker off and remove whatever panels to gain access to the electrical wiring. You should check your incoming power wiring to ground and isolate the source of the short.
Is there another outlet sharing the same circuit breaker?
1- Unplug the dis washer.
2- Turn on the Circuit breaker
a- if it didn't reset while there is some other outlet sharing meaning something shorted other than from the dishwasher.
b- if didn't reset with no other outlet shared the same circuit breaker, then your circuit breaker is bad.
c- if it resets with no other outlet shared the same circuit breaker, then ther is a shortage from your dis washer.
3- After address the issue with circuit breaker you will probably know if there is a problem with your dishwasher then we can go from there.
