Hi ... the refrigerator part is NOT getting cold any longer ...but the freezer is freezing .... please help
SOURCE: kenmore 73503 not cold enough
Is the fan in the freezer working?? Is there Ice on the rear panel in the freezer?
SOURCE: Kenmore cold spot refrigerator freezer
wow you have power to the unit what about the temp control ? is it turned up?? if so is it closed(calling for cooling?) that is the place to start you can jumper it after yo unplug it to see if you dont have a meter
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
SOURCE: Kenmore side by side is not getting cold or freezing
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
Is the refrigerator completely dead?
If so, see “It's stopped completely.”
The compressor
is a football-sized case with no apparent moving parts. It's on the
outside of the refrigerator at the back near the bottom. If it is
humming or making a continuous noise and your refrigerator is still not
cooling, there may be a more serious problem with one or more of
several different components, we recommend contacting a qualified
appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
The compressor
The Thermostat
The overload, relay, or capacitor
The defrost timer
The condenser fan motor
The freezer and the fridge are cooled by the same system, air is moved to the fridge by a fan from the freezer, either the circulation fan is defective or the fridge thermostat is defective.
Regards:
VOTIT
Don't forget to rate;
SOURCE: Kenmore 596.72913200 refrigerator cold, freezer cold but not freezing
good day,
hope this link below will solve your problem.
ref
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
wrong.
If
tips.
Check
you...
Coil Cleaning
Refrigerator Repair
Refrigerator
Troubleshooting
Refrigerator
Compressor
Refrigerator
heatman101
