Master
- Posted on Jul 02, 2009
Re: Ours kitchenaid icemaker has stopped making ice. It...
Hello. i can assist you.
If the ice maker is
producing ice poorly--making small cubes or too few cubes--you probably have a
clogged water line, a defective water-inlet valve, or a defective ice maker mold
thermostat that isn't cycling properly. Check these:
- The water line that's attached to the back of the refrigerator. Make sure
you have good water flow. If the flow is poor, repair, clean, or replace the
tubing or the shut-off valve that supplies the water.
- The water-inlet valve. Replace it if it has failed.
- Check the freezer temperature. If should be 8 degrees Fahrenheit or lower.
If the freezer is too warm, the ice maker won't cycle properly.
- The ice maker mold thermostat. Make sure that it's cycling properly.
