Starts well,,runs well, the trim head spins on its own with the engine on..Is that normal? I lowered the idle a little and it did nothing but make the engine run rough !! I can live with it like it is,,just wondered why ??
SOURCE: Ryobi gas string trimmer won't run
I have a RYobi SS30 and it will not run at all. I have pulled the cord about a hundred times, yes after about 10 I should have gotten the picture, but if anyone knows what to do to correct this I would appreciate this. I am not very mechanically inclined so any help would be appreciated
You need to rebuild the carburetor. You will need to go to an outdoor power & equipment store of some kind to get a carburetor kit for your specific trimmer. It will come with various gaskets, (some of which you won't use), a needle valve, and a small screen that goes in the carb. Replace all old parts with new. New primer bulb is sold seperately. When you have the carb. apart, you will also need to clean the small ports with a Den Tek Brush (used for cleaning teeth). Use carb. cleaner when cleaning.
Jim
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
SOURCE: have a ryobi rlt 30 cd and the spool wont spin fast enough
hgffggkgjgjgbTry taping the bottom on a hard surface;HARD!;;;;;;;bjjjjjjkjjjjm4454541joojojojlj That did the trick for me for some reason it doesn't grab and it gets lose were it won't spin fast bearly cutting a blade of grass.
SOURCE: Ryobi SS30 Carburetor Problems
Replace thecarb screen, make sure you can see through the screen
