SOURCE: KDF-E60A20
do this for me turn off tv hit the follow hit this button display,5,vol down, power and till me the error code for this set this a have a
cpu in them ever time the led blink on front of set that mean thear is some pu with tv. so chech it and git back to me with code
thank you. bob..
SOURCE: sony wega 50 inch clicks and flashes 3 times and goes back onto s
If its model number is KF-50WE610, had you replaced its Lamp recently?
If Lamp is replaced, please check Lamp cover/ door that is not seated properly, make sure its fixed securely.
3 times light flashing shows Lamp cover error.
SOURCE: sony 55 inch, pitchure goes out but have sound
probably lamp is getting weak, needs to be replaced.
SOURCE: Sony Grand Wega 60 inch LCD Projection TV goes dark.
most likely, buy you a lamp and install it yourself, the owners manual tells you how to do this.
SOURCE: my 60 inch sony hdtv has a yelow circle in the
THAT COULD JUST BE A DUST SPOT INTERNAL TO THE OPTICAL ENGINE. THE LAMP CAN ONLY AFFECT BRIGHTNESS NOT ANYTHING TO DO WITH COLOR DISTORTIONS. IF IT NEEDS CLEANING I SUGGEST CALLING A SERVICEMAN
