Question about Amana Refrigerators
HOW TO REPLACE THE LIGHT BULB AND REMOVE THE PLASTIC COVER ON THE AFD3525DES MODEL
Anonymous
SOURCE:
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: Dispenser Light broken
you can just unplug the refrig and use a pair of needle noase pliers to remove the base then install a new bulb it can not be over 10watt a night lite one works great (7watt) this will be a better solution that dissably. the panel
Posted on Feb 20, 2008
elhomspam
Raymond Cardona
  • 58 Answers
SOURCE: Don't have old manual....Need tochange
It can be confusing to find the manual but follow these steps
1. go to www.maytag.com
2. click support
3. click manuals
4. Enter model
5. click the use and care guide
6. On page 11 bottom left corner ( my acrobat reader says section 12)
heres the link http://shared.whirlpoolcorp.com/assets/pdfs/literature/MTB1950FRQ.pdf
Posted on May 02, 2008
Ken Bledsoe
  • 306 Answers
SOURCE: how to change a ge refrigerator light bulb
It snaps in place by lifting the plastic cover. Then when you replace push it in then down. It has two tabs one on each end.
Posted on Jan 01, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: How do I remove the
Just squeeze the light cover and it should pop off forwards (ie. away from the fridge side).
Posted on Nov 12, 2010
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How change freezer light bulb on model LFC 21776
yes to both, and I believe to remove the light bulb cover you gently lift up and out to gain access to the bulb.
Sep 18, 2014 | LG LFC21776ST 21 CF French Door Refer Cab...
How do I replace sears side light bulb on door opener
To replace the bulb you have to remove the plastic cover which is held on with tabs and one or two sheet metal screws (usually on the top of the unit). The bulb is in a standard light socket. It is best to replace it with a bulb that resists vibration such as a ceiling fan bulb.
Jul 14, 2014 | Sears Craftsman LiftMaster Chamberlain...
How to remove cover of fridge light to replace bulb
generally there is a Philips screw at the edge of the plastic cover,or sometimes you can squeeze or press in the sides of the cover.Check the make & model and go in line to the company,They usually will have a manual where you can find out the answer.Best of luck.
May 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
Silhouette manual
I am guessing you want to replace the bulb! Remove plastic cover which can be held in place by philips head screw or screws. The plastic cover can have side clips that need to be squeezed in gently to allow them to release from a slot in the fridge. Once the cover is removed, the bulb should be a screw type. Remove and then buy a replacement - the edison screw size and wattage are the most important thing to fit. Bulb shape to suit size behind the cover. Buy at WW or Coles otherwise spare parts on possibly ebay if you can be precise on model etc.
Jan 17, 2014 | Westinghouse Refrigerators
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
Jul 04, 2011 | Whirlpool Refrigerators
The light diffuser cover is broken. The model number of the range hood is HO60488. The range hood dates back to possibly the late 1950's when the house was built.
When faced with the total unavailability of replacement parts, its time to get creative, and make your own diffuser cover. Flat ones
can be easily made - find anything plastic that's semi-translucent (like a plastic milk bottle), and cut it with a utility knife.
I have also used a utility knife to cut a polystyrene diffuser cover
originally intended for a 2-ft x 4-ft suspended ceiling fluorescent light fixture.
In case the diffuser cover you make wants to burn when placed close to a light bulb, replace the bulb with a CFL (compact fluorescent) bulb, which run MUCH cooler than incandescent light bulbs.
Old lampshades can be cut and used, but may need to be ironed flat. The major advantage of lampshade material is that
it can be folded over at the edge once or twice, which will fill space - and possibly hold the cover where a plastic sheet might be too loose.
You'll know that your efforts have met with success when you can easily remove your ne diffuser cover to replace the light bulb.
Feb 20, 2011 | Venmar Kitchen Ranges
Can you please send me the directions to change the light bulb in my Kitchenaid Microwave Oven model # kemc308kss01?
Hi, just follow the instruction below...
1. Essentially, open the oven door and remove the plastic vent strip between oven and microwave (4 screws). There will be 2 screws under that which secure the microwave unit to the frame. Remove those...
2. Open the microwave door and remove the plastic vent shield at the top (3 screws). At that point, the microwave unit will slide out from the frame as describe above. The light is to the rear of the large silver pad (I removed mine to facilitate reaching the light). If you look at the parts diagrams online, it will be obvious what to look for. I have the light out and sure enough, OSRAM 64405S....
Took me maybe 5 minutes to remove...
Take care
Apr 23, 2010 | Kitchen Ranges
How do I replace my tail light bulbs on 1990 LeSabre? How do I get into the assembly to get to the bulb?
OPEN TRUNK LOOK WHERE TAILS LOCATED LOOK FOR LARGE PLASTIC WING NUTS.REMOVE THEM PULL TRUNK LINER AWAY ENOUGH TO REMOVE THE OTHER PLASTIC WING NUTS HOLD THE TAIL LIGHT COVER.WHEN YOU REMOVE ALL THE PLASTIC WING NUTS THE TAIL LIGHT COVER WILL COME OUT ENOUGH FOR YOU TO REMOVE THE BULB.
Nov 02, 2009 | 1990 Buick LeSabre
How to change a ge refrigerator light bulb
Jan 01, 2009 | GE PSW26SGRSS Side by Side Refrigerator
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
