Turn off ignition key - press and hold the mode button - turn on ignition key while holding the mode button - wait 3 sec it will turn off automatically
No. All you can do is replace the TPS. Throttle Position Sensor. Throttle bodies cannot be programmed or reset. All you can do to a throttle body is take it apart and clean it. Just replace the TPS.
It depends on how violent the jerking is? Could be as simple as a plug &/or lead breaking down or as complicated as a fuel delivery problem. Sorry not much help, but I don't have much to go on..
Try disconnecting the battery black cable for 5 minutes to reset the idle speed. Also make sure you don't have an issue with air trapped in the cooling system, did you bleed the air out?
how to delite shetting sing
